vb选择文件夹
2012年7月20日 14:13 本文热度 9969
'新建一个模块Module,复制如下代码到里面
Option   Explicit
Declare   Function   SendMessage   Lib   "user32"   Alias   "SendMessageA"   (   _
          ByVal   hWnd   As   Long,   _
          ByVal   wMsg   As   Long,   _
          ByVal   wParam   As   Long,   _
          ByVal   lParam   As   String)   As   Long
Declare   Function   SHGetPathFromIDList   Lib   "shell32.dll"   Alias   "SHGetPathFromIDListA"   (   _
          ByVal   pidl   As   Long,   _
          ByVal   pszPath   As   String)   As   Long
Declare   Function   SHBrowseForFolder   Lib   "shell32.dll"   Alias   "SHBrowseForFolderA"   (   _
          lpBrowseInfo   As   BROWSEINFO)   As   Long
Type   BROWSEINFO
          hOwner   As   Long
          pidlRoot   As   Long
          pszDisplayName   As   String
          lpszTitle   As   String
          ulFlags   As   Long
          lpfnCallback   As   Long
          lParam   As   Long
          iImage   As   Long
End   Type
Dim   xStartPath   As   String
Function   SelectDir(Optional   StartPath   As   String,Optional   Titel   As   String)   As   String
          Dim   iBROWSEINFO   As   BROWSEINFO
          With   iBROWSEINFO
                  .lpszTitle   =   IIf(Len(Titel),   Titel,   "【请选择文件夹】")
                  .ulFlags   =   7
                  If   Len(StartPath)   Then
                  xStartPath   =   StartPath   &   vbNullChar
                  .lpfnCallback   =   GetAddressOf(AddressOf   CallBack)
                  End   If
          End   With
          Dim   xPath   As   String,   NoErr   As   Long:   xPath   =   Space$(512)
          NoErr   =   SHGetPathFromIDList(SHBrowseForFolder(iBROWSEINFO),   xPath)
          SelectDir   =   IIf(NoErr,   Left$(xPath,   InStr(xPath,   Chr(0))   -   1),   "")
End   Function
Function   GetAddressOf(Address   As   Long)   As   Long
          GetAddressOf   =   Address
End   Function
Function   CallBack(ByVal   hWnd   As   Long,   _
                                      ByVal   Msg   As   Long,   _
                                      ByVal   pData   As   Long)   As   Long
          Select   Case   Msg
                  Case   1
                          Call   SendMessage(hWnd,   1126,   1,   xStartPath)
                  Case   2
                          Dim   sDir   As   String   *   64,   tmp   As   Long
                          tmp   =   SHGetPathFromIDList(pidl,   sDir)
                          If   tmp   =   1   Then   SendMessage   hWnd,   1124,   0,   sDir
          End   Select
End   Function
'在窗体中:
dim   strDir   as   String
strDir   =   SelectDir("C:\",   "呵呵,请选择所需的文件夹")'假设初始路径为"C:\"
'strDir中就保存了所选的文件夹
该文章在 2012/7/20 14:13:15 编辑过
