如何使用 websocket 完成 socks5 网络穿透
2025年5月8日 8:21 本文热度 4765
有盆友好奇所谓的网络穿透是怎么做的
然后talk is cheap,please show code
所以只好写个简单且常见的websocket例子,
这里的例子大致是这个原理
浏览器插件(或者其他)首先将正常访问请求 --> 转换为socks5访问 --> 假代理服务器建立websocket链接,然后传输socks5协议数据 --> 允许websocket的网关由于不解析websocket数据而不知道是socks5所以未做拦截 --> 真代理服务器从websocket中解析socks5进行转发处理
代码如下
Socks5 --> websocket 端
internal class Socks5ToWSMiddleware : ITcpProxyMiddleware
    private readonly IForwarderHttpClientFactory httpClientFactory;
    private readonly ILoadBalancingPolicyFactory loadBalancing;
    private readonly ProxyLogger logger;
    private readonly TimeProvider timeProvider;
    public Socks5ToWSMiddleware(IForwarderHttpClientFactory httpClientFactory, ILoadBalancingPolicyFactory loadBalancing, ProxyLogger logger, TimeProvider timeProvider)
        this.httpClientFactory = httpClientFactory;
        this.loadBalancing = loadBalancing;
        this.logger = logger;
        this.timeProvider = timeProvider;
    public Task InitAsync(ConnectionContext context, CancellationToken token, TcpDelegate next)
        // 过滤符合的路由配置
        var feature = context.Features.Get<IL4ReverseProxyFeature>();
        if (feature is not null)
            var route = feature.Route;
            if (route is not null && route.Metadata is not null
                && route.Metadata.TryGetValue("socks5ToWS", out var b) && bool.TryParse(b, out var isSocks5) && isSocks5)
                feature.IsDone = true;
                route.ClusterConfig?.InitHttp(httpClientFactory);
                return Proxy(context, feature, token);
        return next(context, token);
    private async Task Proxy(ConnectionContext context, IL4ReverseProxyFeature feature, CancellationToken token)
    { // loadBalancing 选取有效 ip
        var cluster = route.ClusterConfig;
        DestinationState selectedDestination;
        if (cluster is null)
            selectedDestination = null;
        else
            selectedDestination = feature.SelectedDestination;
            selectedDestination ??= loadBalancing.PickDestination(feature);
        if (selectedDestination is null)
            logger.NotFoundAvailableUpstream(route.ClusterId);
            Abort(context);
            return;
        selectedDestination.ConcurrencyCounter.Increment();
        try
            await SendAsync(context, feature, selectedDestination, cluster, route.Transformer, token);
            selectedDestination.ReportSuccessed();
        catch
            selectedDestination.ReportFailed();
            throw;
        finally
            selectedDestination.ConcurrencyCounter.Decrement();
    private async Task<ForwarderError> SendAsync(ConnectionContext context, IL4ReverseProxyFeature feature, DestinationState selectedDestination, ClusterConfig? cluster, IHttpTransformer transformer, CancellationToken token)
        // 创建 websocket 请求, 这里为了简单,只创建简单 http1.1 websocket
        var destinationPrefix = selectedDestination.Address;
        if (destinationPrefix is null || destinationPrefix.Length < 8)
            throw new ArgumentException("Invalid destination prefix.", nameof(destinationPrefix));
        var requestConfig = cluster.HttpRequest ?? ForwarderRequestConfig.Empty;
        var httpClient = cluster.HttpMessageHandler ?? throw new ArgumentNullException("httpClient");
        var destinationRequest = new HttpRequestMessage();
        destinationRequest.Version = HttpVersion.Version11;
        destinationRequest.VersionPolicy = HttpVersionPolicy.RequestVersionOrLower;
        destinationRequest.Method = HttpMethod.Get;
        destinationRequest.RequestUri ??= new Uri(destinationPrefix, UriKind.Absolute);
        destinationRequest.Headers.TryAddWithoutValidation(HeaderNames.Connection, HeaderNames.Upgrade);
        destinationRequest.Headers.TryAddWithoutValidation(HeaderNames.Upgrade, HttpForwarder.WebSocketName);
        destinationRequest.Headers.TryAddWithoutValidation(HeaderNames.SecWebSocketVersion, "13");
        destinationRequest.Headers.TryAddWithoutValidation(HeaderNames.SecWebSocketKey, ProtocolHelper.CreateSecWebSocketKey());
        destinationRequest.Content = new EmptyHttpContent();
        if (!string.IsNullOrWhiteSpace(selectedDestination.Host))
            destinationRequest.Headers.TryAddWithoutValidation(HeaderNames.Host, selectedDestination.Host);
        // 建立websocket 链接,成功则直接 复制原始 req/resp 数据,不做任何而外处理
        var destinationResponse = await httpClient.SendAsync(destinationRequest, token);
        if (destinationResponse.StatusCode == HttpStatusCode.SwitchingProtocols)
            using var destinationStream = await destinationResponse.Content.ReadAsStreamAsync(token);
            var clientStream = new DuplexPipeStreamAdapter<Stream>(null, context.Transport, static i => i);
            var activityCancellationSource = ActivityCancellationTokenSource.Rent(route.Timeout);
            var requestTask = StreamCopier.CopyAsync(isRequest: true, clientStream, destinationStream, StreamCopier.UnknownLength, timeProvider, activityCancellationSource,
                autoFlush: destinationResponse.Version == HttpVersion.Version20, token).AsTask();
            var responseTask = StreamCopier.CopyAsync(isRequest: false, destinationStream, clientStream, StreamCopier.UnknownLength, timeProvider, activityCancellationSource, token).AsTask();
            var task = await Task.WhenAny(requestTask, responseTask);
            await clientStream.DisposeAsync();
            if (task.IsCanceled)
                Abort(context);
                activityCancellationSource.Cancel();
                if (task.Exception is not null)
                    throw task.Exception;
        else
            Abort(context);
            return ForwarderError.UpgradeRequestDestination;
        return ForwarderError.None;
    public Task<ReadOnlyMemory<byte>> OnRequestAsync(ConnectionContext context, ReadOnlyMemory<byte> source, CancellationToken token, TcpProxyDelegate next)
        return next(context, source, token);
    public Task<ReadOnlyMemory<byte>> OnResponseAsync(ConnectionContext context, ReadOnlyMemory<byte> source, CancellationToken token, TcpProxyDelegate next)
    private static void Abort(ConnectionContext upstream)
        upstream.Transport.Input.CancelPendingRead();
        upstream.Transport.Output.CancelPendingFlush();
        upstream.Abort();
websocket --> Socks5 端
internal class WSToSocks5HttpMiddleware : IMiddleware
    private static ReadOnlySpan<byte> EncodedWebSocketKey => "258EAFA5-E914-47DA-95CA-C5AB0DC85B11"u8;
    private WebSocketMiddleware middleware;
    private readonly Socks5Middleware socks5Middleware;
    public WSToSocks5HttpMiddleware(IOptions<WebSocketOptions> options, ILoggerFactory loggerFactory, Socks5Middleware socks5Middleware)
        middleware = new WebSocketMiddleware(Scoks5, options, loggerFactory);
        this.socks5Middleware = socks5Middleware;
    private async Task Scoks5(HttpContext context)
        var upgradeFeature = context.Features.Get<IHttpUpgradeFeature>();
        // 检查是否未正确 websocket 请求
        var f = context.Features.Get<IHttpWebSocketFeature>();
        if (f.IsWebSocketRequest)
            // 返回 websocket 接受信息
            var responseHeaders = context.Response.Headers;
            responseHeaders.Connection = HeaderNames.Upgrade;
            responseHeaders.Upgrade = HttpForwarder.WebSocketName;
            responseHeaders.SecWebSocketAccept = CreateResponseKey(context.Request.Headers.SecWebSocketKey.ToString());
            var stream = await upgradeFeature!.UpgradeAsync(); // Sets status code to 101
            // 建原始 websocket stream 包装成 pipe 方便使用原来的 socks5Middleware 实现
            var memoryPool = context is IMemoryPoolFeature s ? s.MemoryPool : MemoryPool<byte>.Shared;
            StreamPipeReaderOptions readerOptions = new StreamPipeReaderOptions
                pool: memoryPool,
                bufferSize: memoryPool.GetMinimumSegmentSize(),
                minimumReadSize: memoryPool.GetMinimumAllocSize(),
                leaveOpen: true,
                useZeroByteReads: true
            var writerOptions = new StreamPipeWriterOptions
                pool: memoryPool,
                leaveOpen: true
            var input = PipeReader.Create(stream, readerOptions);
            var output = PipeWriter.Create(stream, writerOptions);
            var feature = context.Features.Get<IReverseProxyFeature>();
            using var cts = CancellationTokenSourcePool.Default.Rent(route.Timeout);
            var token = cts.Token;
            context.Features.Set<IL4ReverseProxyFeature>(new L4ReverseProxyFeature() { IsDone = true, Route = route });
            // socks5Middleware 进行转发
            await socks5Middleware.Proxy(new WebSocketConnection(context.Features)
                Transport = new WebSocketDuplexPipe() { Input = input, Output = output },
                ConnectionId = context.Connection.Id,
                Items = context.Items,
            }, null, token);
        else
            context.Response.StatusCode = StatusCodes.Status400BadRequest;
    public static string CreateResponseKey(string requestKey)
        // "The value of this header field is constructed by concatenating /key/, defined above in step 4
        // in Section 4.2.2, with the string "258EAFA5-E914-47DA-95CA-C5AB0DC85B11", taking the SHA-1 hash of
        // this concatenated value to obtain a 20-byte value and base64-encoding"
        // https://tools.ietf.org/html/rfc6455#section-4.2.2
        // requestKey is already verified to be small (24 bytes) by 'IsRequestKeyValid()' and everything is 1:1 mapping to UTF8 bytes
        // so this can be hardcoded to 60 bytes for the requestKey + static websocket string
        Span<byte> mergedBytes = stackalloc byte[60];
        Encoding.UTF8.GetBytes(requestKey, mergedBytes);
        EncodedWebSocketKey.CopyTo(mergedBytes[24..]);
        Span<byte> hashedBytes = stackalloc byte[20];
        var written = SHA1.HashData(mergedBytes, hashedBytes);
        if (written != 20)
            throw new InvalidOperationException("Could not compute the hash for the 'Sec-WebSocket-Accept' header.");
        return Convert.ToBase64String(hashedBytes);
    public Task InvokeAsync(HttpContext context, RequestDelegate next)
       // 过滤符合的路由配置
                && route.Metadata.TryGetValue("WSToSocks5", out var b) && bool.TryParse(b, out var isSocks5) && isSocks5)
                // 这里偷个懒,利用现成的 WebSocketMiddleware 检查 websocket 请求,
                return middleware.Invoke(context);
        return next(context);
internal class WebSocketConnection : ConnectionContext
    public WebSocketConnection(IFeatureCollection features)
        this.features = features;
    public override IDuplexPipe Transport { get; set; }
    public override string ConnectionId { get; set; }
    private IFeatureCollection features;
    public override IFeatureCollection Features => features;
    public override IDictionary<object, object?> Items { get; set; }
internal class WebSocketDuplexPipe : IDuplexPipe
    public PipeReader Input { get; set; }
    public PipeWriter Output { get; set; }
C# 折叠 复制 全屏
所以利用 websocket 伪装的例子大致就是这样就可以完成 tcp的 socks5 处理了 udp我就不来了
最后有兴趣的同学给 L4/L7的代理 VKProxy点个赞呗 (暂时没有使用文档,等啥时候有空把配置ui站点完成了再来吧)
转自https://www.cnblogs.com/fs7744/p/18863856
该文章在 2025/5/8 8:21:47 编辑过
