C#实现Windows系统远程桌面3389端口来访者IP地址检测并强制断开不在白名单的非法连接
2025年3月13日 12:17 本文热度 6105
​以下是一个C#实现的解决方案,用于C#实现Windows系统远程桌面3389端口来访者IP地址检测,并强制断开不在白名单的非法IP地址连接,支持IPv4和IPv6地址判断,如果是IPv6地址则直接强制断开:
using System;
using System.Net;
using System.Net.NetworkInformation;
using System.Net.Sockets;
using System.Runtime.InteropServices;
namespace TcpConnectionMonitor
    public class TcpConnectionManager
        // IPv4连接结构体
        [StructLayout(LayoutKind.Sequential)]
        public struct MIB_TCPROW
            public uint dwState;
            public uint dwLocalAddr;
            public uint dwLocalPort;
            public uint dwRemoteAddr;
            public uint dwRemotePort;
        // IPv6连接结构体
        public struct MIB_TCP6ROW
            [MarshalAs(UnmanagedType.ByValArray, SizeConst = 16)]
            public byte[] localAddr;
            public uint localScopeId;
            public uint localPort;
            public byte[] remoteAddr;
            public uint remoteScopeId;
            public uint remotePort;
        [DllImport("iphlpapi.dll", SetLastError = true)]
        public static extern int SetTcpEntry(ref MIB_TCPROW pTcpRow);
        public static extern int SetTcpEntry6(ref MIB_TCP6ROW pTcp6Row);
        public static void DisconnectNonWhitelistedConnections(int targetPort, HashSet<string> whiteList)
            IPGlobalProperties properties = IPGlobalProperties.GetIPGlobalProperties();
            TcpConnectionInformation[] connections = properties.GetActiveTcpConnections();
            foreach (TcpConnectionInformation connection in connections)
                if (connection.LocalEndPoint.Port == targetPort)
                    IPAddress remoteAddress = connection.RemoteEndPoint.Address;
                    string remoteIp = remoteAddress.ToString();
                    // 处理IPv6连接
                    if (remoteAddress.AddressFamily == AddressFamily.InterNetworkV6)
                        try
                            MIB_TCP6ROW row6 = new MIB_TCP6ROW
                                dwState = 12, // DELETE_TCB
                                localAddr = connection.LocalEndPoint.Address.GetAddressBytes(),
                                localPort = (uint)IPAddress.HostToNetworkOrder((short)connection.LocalEndPoint.Port),
                                remoteAddr = remoteAddress.GetAddressBytes(),
                                remotePort = (uint)IPAddress.HostToNetworkOrder((short)connection.RemoteEndPoint.Port),
                                localScopeId = 0,
                                remoteScopeId = 0
                            int result = SetTcpEntry6(ref row6);
                            Console.WriteLine(result == 0 ?
                                $"已断开IPv6连接:{remoteIp}" :
                                $"IPv6断开失败(错误码:{result}):{remoteIp}");
                        catch (Exception ex)
                            Console.WriteLine($"处理IPv6连接时出错:{ex.Message}");
                    // 处理IPv4连接
                    else if (!whiteList.Contains(remoteIp))
                        try
                            MIB_TCPROW row = new MIB_TCPROW
                                dwState = 12,
                                dwLocalAddr = BitConverter.ToUInt32(connection.LocalEndPoint.Address.GetAddressBytes(), 0),
                                dwLocalPort = (uint)IPAddress.HostToNetworkOrder((short)connection.LocalEndPoint.Port),
                                dwRemoteAddr = BitConverter.ToUInt32(remoteAddress.GetAddressBytes(), 0),
                                dwRemotePort = (uint)IPAddress.HostToNetworkOrder((short)connection.RemoteEndPoint.Port)
                            int result = SetTcpEntry(ref row);
                                $"已断开IPv4连接:{remoteIp}" :
                                $"IPv4断开失败(错误码:{result}):{remoteIp}");
                            Console.WriteLine($"处理IPv4连接时出错:{ex.Message}");
    class Program
            HashSet<string> whiteList = new HashSet<string>
                "192.168.1.100",
                "10.0.0.5"
            try
                TcpConnectionManager.DisconnectNonWhitelistedConnections(3389, whiteList);
                Console.WriteLine($"运行时错误:{ex.Message}");
  1. 双协议支持:
    • 新增MIB_TCP6ROW结构体处理IPv6连接
    • 添加SetTcpEntry6 API调用接口
  2. 智能检测逻辑:
    // 强制断开所有IPv6连接
    // 处理非白名单IPv4连接
  1. 增强的错误处理:
    • 分离IPv4/IPv6的错误日志
    • 明确显示操作结果和错误码
使用注意事项:
  1. 需要先添加System.Net.NetworkInformation引用
  2. 白名单IP需根据实际情况修改
  3. 测试前建议改用非关键端口进行验证
  4. 生产环境应考虑添加日志记录和异常处理
  1. 权限要求:
    • 程序需要以管理员权限运行,否则无法修改TCP连接表。
    • 需要启用IPv6支持的操作系统
  2. 端口范围:
    • 支持同时监控IPv4和IPv6的3389端口
    • 自动过滤其他端口流量
  3. 网络字节序:
    • 自动处理IPv6地址的128位字节转换
    • 正确转换端口号的网络字节序
  4. 结构体转换:
    1. 使用MIB_TCPROW结构体与Windows API交互
    2. IP地址和端口需要转换为网络字节序
  5. 白名单检查:直接使用HashSet进行快速查找
  6. 日志输出:
    • 明确区分IPv4/IPv6操作结果
    • 显示API调用的详细错误码
该版本实现了对IPv6连接的主动断开功能,同时优化了以下方面:
  1. 使用更精确的地址族检测逻辑
  2. 改进结构体字段的初始化方式
  3. 增强网络字节序转换的可靠性
  4. 提供更详细的运行时反馈信息
对于无法处理的连接类型(如IPv6连接在旧系统上的兼容性问题),程序会通过错误码反馈具体故障原因。
此代码会实时检测所有连接到3389端口的TCP连接,并自动断开非白名单IP的连接,有效增强RDP服务的安全性。
其他注意事项:
1、HashSet 白名单地址维护方法参见:http://29753.oa22.cn​
2、Windows系统的远程桌面端口是允许更改的,所以更稳妥的做法是要先读取Windows系统远程桌面的服务端口,以下是获取远程桌面服务端口的代码:
string PortNumber = "";
RegistryKey localKey = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, Environment.Is64BitOperatingSystem ? RegistryView.Registry64 : RegistryView.Registry32);
//远程桌面端口,判断操作系统版本(64位\32位)打开注册表项
try
    RegistryKey rk_Winlogon = localKey.OpenSubKey(@"System\CurrentControlSet\Control\Terminal Server\Wds\rdpwd\Tds\Tcp", true);
    if (rk_Winlogon != null)
        foreach (string vname in rk_Winlogon.GetValueNames())
            if (vname == "PortNumber")
                PortNumber = rk_Winlogon.GetValue("PortNumber").ToString();
                break;
        rk_Winlogon.Close();
catch (Exception) { }
该文章在 2025/3/13 12:46:51 编辑过
