C#根据弹窗标题获取窗体句柄并模拟点击按钮(FindWindow,FindWindowEx,SendMessage)
2023年9月14日 18:35 本文热度 6549
任务:将下面弹窗自动关闭
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
/// <summary>
/// 找到窗口
/// </summary>
/// <param name="lpClassName">窗口类名(例:Button)</param>
/// <param name="lpWindowName">窗口标题</param>
/// <returns></returns>
[DllImport("user32.dll", EntryPoint = "FindWindow")]
private extern static IntPtr FindWindow(string lpClassName, string lpWindowName);
/// <summary>
/// 找到窗口
/// </summary>
/// <param name="hwndParent">父窗口句柄(如果为空,则为桌面窗口)</param>
/// <param name="hwndChildAfter">子窗口句柄(从该子窗口之后查找)</param>
/// <param name="lpszClass">窗口类名(例:Button</param>
/// <param name="lpszWindow">窗口标题</param>
[DllImport("user32.dll", EntryPoint = "FindWindowEx")]
private extern static IntPtr FindWindowEx(IntPtr hwndParent, IntPtr hwndChildAfter, string lpszClass, string lpszWindow);
/// <summary>
/// 发送消息
/// </summary>
/// <param name="hwnd">消息接受窗口句柄</param>
/// <param name="wMsg">消息</param>
/// <param name="wParam">指定附加的消息特定信息</param>
/// <param name="lParam">指定附加的消息特定信息</param>
[DllImport("user32.dll", EntryPoint = "SendMessageA")]
private static extern int SendMessage(IntPtr hwnd, uint wMsg, int wParam, int lParam);
//窗口发送给按钮控件的消息,让按钮执行点击操作,可以模拟按钮点击
private const int BM_CLICK = 0xF5;
 通过窗体标题,循环查找该窗体,然后找到确定按钮,通过句柄发送点击消息,主动关闭弹窗
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
private void Form1_Load(object sender, EventArgs e)
           Task task = new Task(() =>
               while (true)
                   //测试警告框
                   IntPtr maindHwnd = FindWindow(null, "提示");//主窗口标题
                   if (maindHwnd != IntPtr.Zero)
                       IntPtr childHwnd = FindWindowEx(maindHwnd, IntPtr.Zero, null, "确定");//按钮控件标题
                       if (childHwnd != IntPtr.Zero)
                           SendMessage(childHwnd, BM_CLICK, 0, 0);
           task.Start();
该文章在 2023/9/14 18:35:00 编辑过
