[点晴永久免费OA]【ASP】将HEX十六进制颜色转换为RGB后加深或减淡,然后再还原为HEX颜色函数
2023年4月14日 1:15 本文热度 5868
'tmpHexColor-十六进制颜色,以#开头;tmpValue-正数减淡、负数加深,一般取60-80才会有明显的变化
function changeColorDeep(tmpHexColor, tmpValue)
changeColorDeep=tmpHexColor
if left(tmpHexColor &"CS",1)="#" then
tmp_hexval = right(tmpHexColor,6)
tmp_rgbval = CLng("&h" & tmp_hexval)
tmp_r_RGB = (tmp_rgbval And &hff0000&)/65536+(tmpValue)
tmp_g_RGB= (tmp_rgbval And &h00ff00&)/256+(tmpValue)
tmp_b_RGB= (tmp_rgbval And &h0000ff&)+(tmpValue)
if not len(tmp_r_RGB)=0 and not len(tmp_g_RGB)=0 and not len(tmp_b_RGB)=0 and isnumeric(tmp_r_RGB) and isnumeric(tmp_g_RGB) and isnumeric(tmp_b_RGB) then
if cint(tmp_r_RGB)<0 then tmp_r_RGB=0
if cint(tmp_r_RGB)>255 then tmp_r_RGB=255
if cint(tmp_g_RGB)<0 then tmp_g_RGB=0
if cint(tmp_g_RGB)>255 then tmp_g_RGB=255
if cint(tmp_b_RGB)<0 then tmp_b_RGB=0
if cint(tmp_b_RGB)>255 then tmp_b_RGB=255
tmp_r_HEX=hex(tmp_r_RGB)
tmp_g_HEX=hex(tmp_g_RGB)
tmp_b_HEX=hex(tmp_b_RGB)
if len(tmp_r_HEX)=1 then tmp_r_HEX="0" & tmp_r_HEX
if len(tmp_g_HEX)=1 then tmp_g_HEX="0" & tmp_g_HEX
if len(tmp_b_HEX)=1 then tmp_b_HEX="0" & tmp_b_HEX
changeColorDeep="#" & tmp_r_HEX & tmp_g_HEX & tmp_b_HEX
else
changeColorDeep="#000000"
end if
end if
end function
该文章在 2023/4/20 11:19:48 编辑过
