C# 按质量等级压缩图片(二)
2023年2月27日 10:46
本文热度 6041
这一篇我们呢采用的压缩方式跟上一篇是一样的,不同的是,这次我们会同时融入一个等比压缩宽高的方法,这两个一起使用,会使文件空间大幅度减小,同时也可以单独压缩宽高,质量等级不要变(直接用100即可);
实现功能:
开发环境:
开发工具:Visual Studio 2013
.NET Framework版本:4.5
实现代码:
private void btnOld_Click(object sender, EventArgs e) { OpenFileDialog ofd = new OpenFileDialog(); ofd.Filter = "图片|*.jpg;*.jpeg;*.png"; if (ofd.ShowDialog() == DialogResult.OK) { txtOld.Text = ofd.FileName; } }
private void btnNew_Click(object sender, EventArgs e) { FolderBrowserDialog fbd = new FolderBrowserDialog(); fbd.ShowNewFolderButton = true; if (fbd.ShowDialog() == DialogResult.OK) { txtNew.Text = fbd.selectedPath; } }
private void btnCompressSize_Click(object sender, EventArgs e){ ImgSizeCompress(10L); ImgSizeCompress(50L); ImgSizeCompress(70L); MessageBox.Show("成功");}
private void ImgSizeCompress(long level) { Image img = Image.fromFile(txtOld.Text); ImageFormat imgFormat = img.RawFormat;
Size newSize = new Size(img.Width / 2, img.Height / 2); Bitmap outBmp = new Bitmap(newSize.Width, newSize.Height);
Graphics g = Graphics.fromImage(outBmp); g.CompositingQuality = CompositingQuality.HighQuality; g.SmoothingMode = SmoothingMode.HighQuality; g.InterpolationMode = InterpolationMode.HighQualityBicubic; g.DrawImage(img, new Rectangle(0, 0, newSize.Width, newSize.Height), 0, 0, img.Width, img.Height, GraphicsUnit.Pixel); g.Dispose(); img.Dispose();
EncoderParameters encoderParams = new EncoderParameters(); encoderParams.Param[0] = new EncoderParameter(System.Drawing.Imaging.Encoder.Quality, level);
ImageCodecInfo codecInfo = GetEncoder(imgFormat); string savePath = txtNew.Text + "\\" + DateTime.Now.Ticks + "." + codecInfo.FormatDescription; outBmp.Save(savePath, codecInfo, encoderParams); outBmp.Dispose(); }
private ImageCodecInfo GetEncoder(ImageFormat format) { ImageCodecInfo[] codecs = ImageCodecInfo.GetImageEncoders(); foreach (ImageCodecInfo codec in codecs) { if (codec.FormatID == format.Guid) { return codec; } } return null; }
实现效果:
上面是将宽度和高度分别缩小了一半,看得出来,效果还是比较明显的
该文章在 2023/2/27 10:46:40 编辑过
