[点晴永久免费OA]让ASP搭配MYSQL数据库
2022年7月5日 1:32 本文热度 5663
所需要工具:
   mysql-4.1.11-win32
   myodbc-3.51.11-1-dll
   myodbc-3.51.11-1-win
   mysqlcc-0.9.4-win32
注册文件Mydbc.reg:
   REGEDIT4
   [HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI\myodbc driver]
   "UsageCount"=dword:00000002
   "Driver"="C:\\WINDOWS\\System\\myodbc.dll"
   "Setup"="C:\\WINDOWS\\System\\myodbc.dll"
   "SQLLevel"="1"
   "FileUsage"="0"
   "DriverODBCVer"="03.51"
   "ConnectFunctions"="YYY"
   "APILevel"="1"
   "CpTimeout"="120"
   [HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI\ODBC Drivers]
   "myodbc driver"="installed"
建立ASP文件链接数据库,例子如下:
   Windows DSN name: 所要建立DSN的名称
   Mysql Host (name or ip):Mysql服务器的名称或者是IP地址,通常填localhost
   Mysql database name: admin
   Database: admin
   password: 000000
   Port(if not 3306):
   SQL command on connect:
下面两种链接数据库的ASP代码:
1. 使用DSN
  strConnection = "dsn=admin;driver={myodbd driver};server=localhost;uid=root;pwd=000000;database=admin"
  Set adoDataConn = Server.createObject("ADODB.Connection")
  adoDataConn.Open strConnection
  strQuery = "select * from user"
  Set rs = adoDataConn.execute(strQuery)
  If Not rs.BOF Then
  <TABLE>
  <TR>
  <TD<b>username</b></TD>
  <TD><b>password</b></TD>
  </TR>
  Do While Not rs.EOF
  <TR>
  <TD><%=rs("username")%></TD>
  <TD><%=rs("password")%></TD>
  </TR>
  rs.MoveNext
  Loop
  </TABLE>
  Else
  Response.Write("Sorry, no data found.")
  End If
  rs.Close
  adoDataConn.Close
  Set adoDataConn = Nothing
  Set rsEmailData = Nothing
2. 不使用DSN
  strconnection="DefaultDir=;Driver={myodbc driver};database=admin"
  If Not rs.BOF Then
  <TABLE>
  <TR>
  </TR>
  Do While Not rs.EOF
  <TR>
  </TR>
  rs.MoveNext
  Loop
  </TABLE>
  Else
  End If
  rs.Close
  adoDataConn.Close
该文章在 2022/7/5 1:32:16 编辑过
