C# 抓取网页img的src带参数的图片链接,并下载
2021年3月18日 12:8 本文热度 7792
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.IO;
using System.Linq;
using System.Net;
using System.Text;
using System.Text.RegularExpressions;
using System.Threading;
using System.Windows.Forms;
namespace ImageCollection
    public partial class Form1 : Form
        private static string Path = AppDomain.CurrentDomain.BaseDirectory + "img";
        public Form1()
            InitializeComponent();
        private void btnshuaqu_Click(object sender, EventArgs e)
            string url = txturl.Text.Trim();
            if (string.IsNullOrEmpty(url))
                MessageBox.Show("请输入URl");
                return;
            txtimg.AppendText("开始抓取中:\r\n");
            Thread th = new Thread(() => ShuaQu(url)) { IsBackground = true };
            th.Start();
        private void ShuaQu(string url)
            DirectoryInfo di = new DirectoryInfo(Path);
            if (System.IO.Directory.Exists(Path))
                di.Delete(true);
            System.IO.Directory.CreateDirectory(Path);
            string result = WebHttp.HttpGet(url, null, 3);
            string[] str = GetHtmlImageUrlList(result);
            txtimg.Invoke(new Action(() =>
                txtimg.AppendText("已经获取到数据!"+str.Count() + "\r\n");
            //建立获取网页标题正则表达式
            String regex = @"<title>.+</title>";
            //返回网页标题
            String title = Regex.Match(result, regex).ToString();
            txttitle.Invoke(new Action(() => {
                txttitle.Text = Regex.Replace(title, @"[\""]+", "");
            foreach (string s in str)
                Uri u = new Uri(s);
                if (u.Host == "www.xxx.com")
                    Thread downimg = new Thread(() => Get_img(s)) { IsBackground = true };
                    downimg.Start();
                    txtimg.Invoke(new Action(() => {
                        txtimg.AppendText(s + "\r\n");
                txtimg.AppendText("全部抓取完成!\r\n");
        public void Get_img(string imgpath)
            string[] file = imgpath.Split('?');
            string name = System.IO.Path.GetFileName(file[0]);
            WebClient mywebclient = new WebClient();
            mywebclient.DownloadFile(imgpath, Path + @"\" + name);
            //Bitmap img = null;
            //HttpWebRequest req;
            //HttpWebResponse res = null;
            //try
            //    System.Uri httpUrl = new System.Uri(imgpath);
            //    req = (HttpWebRequest)(WebRequest.Create(httpUrl));
            //    req.Timeout = 180000; //设置超时值10秒
            //    req.UserAgent = "XXXXX";
            //    req.Accept = "XXXXXX";
            //    req.Method = "GET";
            //    res = (HttpWebResponse)(req.GetResponse());
            //    img = new Bitmap(res.GetResponseStream());//获取图片流
            //    img.Save(Path + @"\"+name);//随机名
            //catch (Exception ex)
            //    string aa = ex.Message;
            //finally
            //    res.Close();
        /// <summary>
        /// 取得HTML中所有图片的 URL。
        /// </summary>
        /// <param name="sHtmlText">HTML代码</param>
        /// <returns>图片的URL列表</returns>
        private string[] GetHtmlImageUrlList(string sHtmlText)
            // 定义正则表达式用来匹配 img 标签
            Regex regImg = new Regex(@"<img\b[^<>]*?\bsrc[\s\t\r\n]*=[\s\t\r\n]*[""']?[\s\t\r\n]*(?<imgUrl>[^\s\t\r\n""'<>]*)[^<>]*?/?[\s\t\r\n]*>", RegexOptions.IgnoreCase);
            // 搜索匹配的字符串
            MatchCollection matches = regImg.Matches(sHtmlText);
            int i = 0;
            string[] sUrlList = new string[matches.Count];
            // 取得匹配项列表
            foreach (Match match in matches)
                sUrlList[i++] = match.Groups["imgUrl"].Value;
            return sUrlList;
#region 下载图片到Image
public static Image UrlToImage(string url) {
    byte[] Bytes = mywebclient.DownloadData(url);
    using (MemoryStream ms = new MemoryStream(Bytes)) {
        Image outputImg = Image.FromStream(ms);
        return outputImg;
#endregion
该文章在 2021/3/18 12:09:33 编辑过
