[点晴永久免费OA]C#程序B/S打包下载
2020年3月3日 1:38
本文热度 8097
protected void btnAdd_Click(object sender, EventArgs e)
// 创建临时文件夹
string Folder = DateTime.Now.ToString("yyyymmddHHMMss");
string tempFolder = Path.Combine(Server.MapPath("/file"), Folder);
Directory.CreateDirectory(tempFolder);
string[] fs = Directory.GetFiles(Server.MapPath("/files"));
for (int i = 0; i < fs.Length; i++)
File.Copy(fs[i], tempFolder + fs[i].Substring(fs[i].LastIndexOf(''\\''), fs[i].Length - fs[i].LastIndexOf(''\\'')));
//产生RAR文件,及文件输出
RARsave(tempFolder, tempFolder, Folder);
ResponseFile(tempFolder + @"\" + Folder + ".rar");
public void RARsave(string patch, string rarPatch, string rarName)
String the_rar;
RegistryKey the_Reg;
Object the_Obj;
String the_Info;
ProcessStartInfo the_StartInfo;
Process the_Process;
try
the_Reg = Registry.ClassesRoot.OpenSubKey(@"WinRAR");
the_Obj = the_Reg.GetValue("");
the_rar = the_Obj.ToString();
the_Reg.Close();
the_rar = the_rar.Substring(1, the_rar.Length - 7);
Directory.CreateDirectory(patch);
//命令参数
//the_Info = " a " + rarName + " " + @"C:Test?70821.txt"; //文件压缩
the_Info = " a " + rarName + " " + patch + " -r";
the_StartInfo = new ProcessStartInfo();
the_StartInfo.FileName = "WinRar";//the_rar;
the_StartInfo.Arguments = the_Info;
the_StartInfo.WindowStyle = ProcessWindowStyle.Hidden;
//打包文件存放目录
the_StartInfo.WorkingDirectory = rarPatch;
the_Process = new Process();
the_Process.StartInfo = the_StartInfo;
the_Process.Start();
the_Process.WaitForExit();
the_Process.Close();
catch (Exception ex)
throw ex;
protected void ResponseFile(string fileName)
FileInfo fileInfo = new FileInfo(fileName);
Response.Clear();
Response.ClearContent();
Response.ClearHeaders();
Response.AddHeader("Content-Disposition", "attachment;filename=" + fileName);
Response.AddHeader("Content-Length", fileInfo.Length.ToString());
Response.AddHeader("Content-Transfer-Encoding", "binary");
Response.ContentType = "application/octet-stream";
Response.ContentEncoding = System.Text.Encoding.GetEncoding("gb2312");
Response.WriteFile(fileInfo.FullName);
Response.Flush();
string tempPath = fileName.Substring(0, fileName.LastIndexOf("\\"));
DelDir(tempPath);
Directory.Delete(tempPath);
Response.End();
private void DelDir(string path)
string[] fs = Directory.GetFiles(path);
File.Delete(fs[i]);
该文章在 2020/3/3 1:38:32 编辑过
