[点晴永久免费OA]C# 双击ListView出现编辑框可编辑,回车确认
2022年12月22日 20:39 本文热度 1775
1.
获取鼠标点击的项------API
2.          [DllImport("user32")]
3.          public static extern int GetScrollPos(int hwnd, int nBar);
4.
5.          private TextBox txtInput;
6.
7.          //获取点击项的位置
8.          private void lViewPersonWork_MouseDoubleClick(object sender, MouseEventArgs e)
9.          {
10.            try
11.            {
12.                ListViewItem item = this.lViewPersonWork.GetItemAt(e.X, e.Y);
13.
14.                //找到文本框
15.                Rectangle rect = item.GetBounds(ItemBoundsPortion.Entire);
16.                int StartX = rect.Left; //获取文本框位置的X坐标
17.                int ColumnIndex = 0;    //文本框的索引
18.
19.                //获取列的索引
20.                //得到滑块的位置
21.                int pos = GetScrollPos(this.lViewPersonWork.Handle.ToInt32(), 0);
22.                foreach (ColumnHeader Column in lViewPersonWork.Columns)
23.                {
24.                    if (e.X + pos >= StartX + Column.Width)
25.                    {
26.                        StartX += Column.Width;
27.                        ColumnIndex += 1;
28.                    }
29.                }
30.
31.                if (ColumnIndex < this.lViewPersonWork.Columns.Count - 1)
32.                {
33.                    return;
34.                }
35.
36.                this.txtInput = new TextBox();
37.
38.                //locate the txtinput and hide it. txtInputTextBox
39.                this.txtInput.Parent = this.lViewPersonWork;
40.
41.                //begin edit
42.                if (item != null)
43.                {
44.                    rect.X = StartX;
45.                    rect.Width = this.lViewPersonWork.Columns[ColumnIndex].Width; //得到长度和ListView的列的长度相同
46.                    this.txtInput.Bounds = rect;
47.                    this.txtInput.Multiline = true;
48.                    //显示文本框
49.                    this.txtInput.Text = item.SubItems[ColumnIndex].Text;
50.                    this.txtInput.Tag = item.SubItems[ColumnIndex];
51.                    this.txtInput.KeyPress += new KeyPressEventHandler(txtInput_KeyPress);
52.                    this.txtInput.Focus();
53.                }
54.            }
55.            catch (Exception ex)
56.            {
57.
58.            }
59.        }
60.
61.        //回车保存内容
62.        private void txtInput_KeyPress(object sender, KeyPressEventArgs e)
63.        {
64.            try
65.            {
66.                if ((int)e.KeyChar == 13)
67.                {
68.                    if (this.txtInput != null)
69.                    {
70.                        ListViewItem.ListViewSubItem lvst = (ListViewItem.ListViewSubItem)this.txtInput.Tag;
71.
72.                        lvst.Text = this.txtInput.Text;
73.
74.                        this.txtInput.Dispose();
75.                    }
76.                }
77.            }
78.            catch (Exception ex)
79.            {
80.
81.            }
82.        }
83.
84.        //释放文本框内容
85.        private void lViewPersonWork_selectedIndexChanged(object sender, EventArgs e)
86.        {
87.            try
88.            {
89.                if (this.txtInput != null)
90.                {
91.                    if (this.txtInput.Text.Length > 0)
92.                    {
93.                        ListViewItem.ListViewSubItem lvst = (ListViewItem.ListViewSubItem)this.txtInput.Tag;
94.
95.                        lvst.Text = this.txtInput.Text;
96.                    }
97.
98.                    this.txtInput.Dispose();
99.                }
100.               }
101.               catch (Exception ex)
102.               {
103.
104.               }
105.           }
该文章在 2022/12/22 20:41:39 编辑过
